Print at Sep 6, 2026, 10:12:24 AM
Posted by hal9000 at Jul 10, 2013, 9:50:27 PM
Re: Problem with File open
I just meant the filesystem permissions for your user or group. If you can open files on another folders, with a file explorer for example, then you have the permissions. May be Java has not the correct permissions then?
As a workaround you can simply copy the file to your home folder, work on it and then, if needed, copy it back to the origin folder.
