Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Where does SH save its .obj-list? » » » » Post: Re: Where does SH save its .obj-list? |
Print at Aug 19, 2026, 4:54:38 PM |
| Posted by Puybaret at May 29, 2013, 11:46:19 AM |
Re: Where does SH save its .obj-list? One tip though: the category of each object is stored in the preferences.xml file. You could edit this file with any text editor, and change the text between > and < in the lines starting by <entry key="furnitureCategory#, like: <entry key="furnitureCategory#4">Other</entry><entry key="furnitureCategory#4">My category</entry>The problem is that it won't be easy to recognize each piece of furniture since they are identified by a number and not by their name (the name you gave to an imported object is defined in the entries with a key starting by furnitureName#). Before doing any tests be sure to create a backup of your eTeks/SweetHome3D folder. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 19, 2026, 4:54:38 PM |
