Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: It is possible modify export to SVG format ? » » » » Post: Re: It is possible modify export to SVG format ? |
Print at Jul 22, 2026, 6:11:43 AM |
| Posted by Puybaret at May 15, 2013, 3:01:19 PM |
Re: It is possible modify export to SVG format ? If you want to change SVG export, you should change the implementation of exportToSVG method in the PlanComponent class. In your case, maybe you could simply modify the end of paintFurniture method, to draw your rectangle when the paintMode is equal to PaintMode.EXPORT (you'll see there are already some similar tests for PAINT mode). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Jul 22, 2026, 6:11:43 AM |
