Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Cannot launch Java application... Nice one » » » » Post: Re: Cannot launch Java application... Nice one |
Print at Sep 20, 2026, 12:07:09 PM |
| Posted by Puybaret at Apr 12, 2013, 10:38:42 AM |
Re: Cannot launch Java application... Nice one You must be using a plugin that wasn't compiled for the Java version you use in Mac OS X. Normally, if the programmer of the plug-in prepared it correctly, it should be detected at program launch when the plug-in is loaded, but you seem to find a misconfigured plug-in. Please, open a window in the Finder, choose Go > Go to... menu item, and copy/paste the following text to go to the folder where plug-ins are stored: ~/Library/Application Support/eTeks/Sweet Home 3D/pluginsRemove all the plug-in files you'll find and relaunch Sweet Home 3D to check it works correctly. Then add the plug-ins one by one, relaunching the program each time, until you find the one that fails. Hope you can handle it and report here the wrong plug-in. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 12:07:09 PM |
