Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Small black square "dots" on high quality renderings » » » » Post: Re: Small black square "dots" on high quality renderings |
Print at Sep 20, 2026, 3:25:23 AM |
| Posted by Puybaret at Apr 6, 2013, 3:50:02 PM |
Re: Small black square "dots" on high quality renderings Sorry Bernd for this bug. It's miserably very difficult for me to improve this, because I'm not the author of SunFlow the rendering engine used at the two best quality levels. I modified it to avoid it hangs, but the result is some black spots. Nevertheless, the version 4 gives you some tools to improve this: - I think that this spots are bound to the shininess level of some objects. Thus reducing the shininess of the materials of the objets that show the spots should help. - It's now possible to adjust many settings of SunFlow with some parameters given to the program. Rendering will be slower if you require a better quality, but it might help reducing the spots. The idea is that all the settings shown in the file PhotoRenderer.properties (used to set the default parameters of the renderer) can be changed by the user with System properties given at program launch (for example, under Windows, you could use the -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.max=3 in a SweetHome3D.l4j.ini file stored beside sweethome3d.exe, to improve the best rendering quality). Expect an article about this in the coming weeks. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 3:25:23 AM |
