Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Import » » » » Post: Re: Import |
Print at Aug 14, 2026, 3:05:29 AM |
| Posted by hansmex at Apr 5, 2013, 4:26:18 PM |
Re: Import Stanislav, You should export each component individually, as follows: - select one component - export it using 3D view --> Export to OBJ format - give it a name - choose Export selection You can then choose to individually import each model, or make a library file using the Library editor. Once you have imported the individual components, you can use them as standard parts to build other models. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Aug 14, 2026, 3:05:29 AM |
