Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: rendering best-quality photos. » » » » Post: Re: rendering best-quality photos. |
Print at Oct 1, 2026, 12:24:29 AM |
| Posted by hansmex at Apr 5, 2013, 1:32:52 PM |
Re: rendering best-quality photos. Austin, Windows 63 bit operating system... Wow! There are several reasons why you can't render your picture. Here are two tricks that I have used in the past to solve problems. - There is a faulty model in your design. To find out if this is the case, use Delete and Undo to find out which one it is. First delete half of your models and try to make the render. If it works, you know one of the deleted models causes the problem. If not, restore those models and delete the other half. Using this method you can narrow down which model causes the problem. - The file is too big. If your file is very big (25 or 50 Mb or bigger), there is another trick that may help. Even if a model will not be visible in the render, SH3D takes it into account when calculating the render. Solution: temporarily make invisible, or delete, all the models that will not be visible in the picture you are trying to make. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Oct 1, 2026, 12:24:29 AM |
