Hello,
first of all thanks a lot for this great and powerful program!
I have a problem, opening saved files on a PC running Windows 7.
If the "*.sh3d" contains only walls and rooms, there is no problem.
If it contains windows or doors, the file can't be opened. The error message says "Can't open home 'test.sh3d'"/ "Konnte Wohnung 'test.sh3d' nicht öffen".
On a PC running Windows XP, exactly the same file can be opened without any problems.
Can you help me to solve this bug?
"Can't open home" (Windows 7)
This topic has been viewed 6944 times and has 6 replies
Re: "Can't open home" (Windows 7)
How many times did you try?
Does it really happen as soon as you add a piece of furniture, a door or a window to your plan?
Does it happen also if there's just one piece?
anagrom_ataf
I tried it several times and on different PCs. (Another PC running Windows 7 created the same problem.)
At first I saved a plan containing only walls, closed the program and opened the file again.
As soon as I add to this same plan or a door or a window or a piece of furniture, I can't open this file again. There is no difference, if there are more pieces or only one.
I never heard about such an issue. Really strange. [:(]
Could you [url=mailto:[email protected]]send me[/url] that file please?
Thanks for the test files you sent me. I had no problem to open them under Mac OS X and Windows 7. You should know that SH3D files are zip files, and wonder if it's possible that some antivirus software or a zip utility could interfere with Sweet Home 3D, even if I never heard about such a problem.
anagrom_ataf
Deinstalling 7Zip, installing WinRAR, deactivating Avira AntiVir doesn't change anything... I'll use the other computer!
Thank you nevertheless!
Hello.
I have same problem on two computers with windows 7 prof x64. The file can't be opened. The error message says "Can't open home 'test.sh3d'". The file was created on this computer.
On a PC running Windows 2003, the same file can be opened without any problems.
P.S If the "*.sh3d" contains only walls and rooms, there is no problem. If I add a piece of furniture, a door or a window - the file can't be opened.
Who is online
Users browsing this forum: Semrush [Bot] and 3 guests
