Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Rotate Room » » » » Post: Re: Rotate Room |
Print at Sep 6, 2026, 7:08:11 AM |
| Posted by hansmex at Mar 27, 2013, 1:21:39 PM |
Re: Rotate Room Chris, If you install the RotateHome plug-in, there's a nice trick that's not documented (yet). Because the Levels feature didn't exist in SH3D at the time the plug-in was written, it was impossible to foresee how the plug-in would behave. It turns out that you can rotate the background plan and models per individual level. This offers the possibility to import your model on a second level, rotate it to the correct position, then copy it to the level where you assemble your building. By the way, you should note that the RotateHome plug-in rotates in 90 degree steps only. Maybe it's a good idea to ask the developer of the plug-in to add a feature to rotate in 1 degree increments. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 6, 2026, 7:08:11 AM |
