Print at Aug 22, 2026, 7:15:00 PM
Posted by StNff at Mar 24, 2013, 12:50:59 PM
Re: <font><font class=""> Re: Проблема Начиная Электронная версия </font></font>
I had JDK 7.
Now I have JDK 5 (As in the instructions).
Log compilation:
D:\1>ant javaWebStart
Buildfile: D:\1\build.xml
build:
[mkdir] Created dir: D:\1\build\classes
[javac] D:\1\build.xml:43: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to f
alse for repeatable builds
[javac] Compiling 2 source files to D:\1\build\classes
[javac] D:\1\build.xml:46: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to f
[javac] Compiling 193 source files to D:\1\build\classes
[javac] Note: Some input files use unchecked or unsafe operations.
[javac] Note: Recompile with -Xlint:unchecked for details.
[copy] Copying 261 files to D:\1\build\classes
[zip] Building zip: D:\1\build\SweetHome3D.jar
[delete] Deleting directory D:\1\build\classes
application:
[zip] Building zip: D:\1\build\SweetHome3DStandalone.jar
[move] Moving 1 file to D:\1\build
furniture:
[zip] Building zip: D:\1\build\Furniture.jar
textures:
[zip] Building zip: D:\1\build\Textures.jar
help:
[zip] Building zip: D:\1\build\Help.jar
jogl-java3d:
[zip] Building zip: D:\1\build\macosx\java3d-1.6\jogl-java3d.jar
java3dLibraries:
[mkdir] Created dir: D:\1\deploy\lib\windows\i386
[zip] Building zip: D:\1\deploy\lib\windows\i386\java3d.jar
[mkdir] Created dir: D:\1\deploy\lib\windows\x64
[zip] Building zip: D:\1\deploy\lib\windows\x64\java3d.jar
[mkdir] Created dir: D:\1\deploy\lib\linux\i386
[zip] Building zip: D:\1\deploy\lib\linux\i386\java3d.jar
[mkdir] Created dir: D:\1\deploy\lib\linux\x64
[zip] Building zip: D:\1\deploy\lib\linux\x64\java3d.jar
[mkdir] Created dir: D:\1\deploy\lib\macosx
[zip] Building zip: D:\1\deploy\lib\macosx\java3d.jar
javaWebStart:
[mkdir] Created dir: D:\1\build\JNLP-INF
[copy] Copying 1 file to D:\1\build\JNLP-INF
[zip] Building zip: D:\1\deploy\lib\SweetHome3DJavaWebStartBootstrap.jar
[zip] Building zip: D:\1\deploy\lib\SweetHome3D.jar
[copy] Copying 6 files to D:\1\deploy\lib
[input] Enter Passphrase for keystore:
1111
[signjar] Signing JAR: D:\1\deploy\lib\Loader3DS1_2u.jar to D:\1\deploy\lib\Loader3DS1_2u.jar as SweetHome3D
[signjar] jarsigner error: java.lang.RuntimeException: keystore load: D:\1\keys.keytool (═х єфрхЄё  эрщЄш єърчрээ√щ Їр
щы)
BUILD FAILED
D:\1\build.xml:238: jarsigner returned: 1
Total time: 1 minute 40 seconds
Tell me, what's the problem?
