Print at Sep 20, 2026, 5:42:41 AM
Posted by xtal_01 at Feb 15, 2013, 11:03:23 PM
Re: "gray block" problem when dropping in furnature .....
I should add the gray block is only at one end. If I copy and paste a this item then rotate it 180, the block is at the other end. It is only visible from "one side". In other words, if I have the same item, side by side and rotate one 180 degrees, I can see a gray block at the end of one roof section when looking at the house from the front and then when rotated so that I am looking at the back, I see the other roof section with a gray block on it.
thanks .... Mike
