Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Need some Help with Roof and Ceiling ??? » » » » Post: Re: Need some Help with Roof and Ceiling ??? |
Print at Aug 21, 2026, 9:56:30 AM |
| Posted by Puybaret at Feb 12, 2013, 7:55:24 PM |
Re: Need some Help with Roof and Ceiling ??? If you change the height of roof parts, you should be able to reach the 90° angle you target. You can also import again the Red slate roof 3D model, and change its orientation degree by degree in the second step of the furniture import wizard. Ceilings can be seen only from below. You should create a room at the upper level. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 21, 2026, 9:56:30 AM |
