Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Room size in java code » » » » Post: Re: Room size in java code |
Print at Aug 22, 2026, 8:27:59 PM |
| Posted by Sajmmon at Jan 16, 2013, 11:44:39 PM |
Re: Room size in java code Home refers in SweetHome to an open project. Walls are walls. Room refers to a polygon drawn on ground/level (and the ceiling is associated with the polygon as well). You can also create a room just by drawing walls - without floor (our Room). It might be misleading, but I am sure that after playing a bit with user interface you will understand the underlying Java classes. Good luck. |
Current timezone is GMT Aug 22, 2026, 8:27:59 PM |
