Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Starting a non square plan » » » » Post: Re: Starting a non square plan |
Print at Sep 22, 2026, 2:15:33 AM |
| Posted by Puybaret at Jan 2, 2013, 12:45:03 PM |
Re: Starting a non square plan As you probably have measures of the inner room (and not in the middle of the walls), you should rather use Hans' suggestion but using the Create rooms tool. Once your room is created, you can easily create the walls around it by double clicking in the room while using the Create walls tool. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 22, 2026, 2:15:33 AM |
