Print at Sep 19, 2026, 10:08:58 PM
Posted by binoc at Sep 21, 2012, 4:54:58 PM
Re: default.sh3d file not found
Hi, Thank U for your response !-)
Of course I reed the README.TXT !
I have followed the instructions : import the src package into an Eclipse project, then filled the VM arguments with the relative path to the lib & lib/windows/i386.
And I try to launch either the 3D applet or the viewer from the run menu but it doesn't works in both case ...
What do you mean by "is within Sweet Home 3D" ? From where exactly the program try to load this default file ?
(I use a Java 7 JDK under Windows 7 32bits)
