Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Adapt level interface » » » » Post: Re: Adapt level interface |
Print at Sep 26, 2026, 1:34:49 AM |
| Posted by kbon at Aug 7, 2012, 12:28:52 PM |
Re: Adapt level interface This is a nice suggestion, as it took me quite a while (and few experiments) to figure out the meanings and behaviour of the level settings :) Additional suggestion: * "Elevation topside" should be modifyable as well, as * 1,2 and 3 are all related to each other. Why not allowing modification of 3 and automatic adaption of 1 or 2? To figure out which one should be adapted, * add radio-buttons in front of 1,2,3 where only one of them can be selected. The selected field would be "static", the others dynamic. Or, if the radio-button stuff is too complicated and vulnerable for errors, let only 1 and 3 affect each other, i.e. changing one would automatically calculate the other depending on floor height. Example: I know my Floor has 25cm thickness. I set it, and put it as "static". Now it wouldn't matter which field (1 or 3) I set, the other would be automatically adapted instantly. This would make it more flexible to modify the fields. One more aspect, that I still don't quite understand about the levels: The "Height above topside" would be the same as the currently available "Height". What use does that field have, except the automatic calculation of a new added level? As far as I can see, none!? It doesn't set any restrictions or anything else. Right? ^^ |
Current timezone is GMT Sep 26, 2026, 1:34:49 AM |
