Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: use private elements of the classes HomePane and HomeController for made a plugin to export the furniture in separated obj » » » » Post: Re: use private elements of the classes HomePane and HomeController for made a plugin to export the furniture in separated obj |
Print at Sep 19, 2026, 8:38:00 PM |
| Posted by Puybaret at Jun 22, 2012, 9:00:27 PM |
Re: use private elements of the classes HomePane and HomeController for made a plugin to export the furniture in separated obj I think you missed the following point: Version 3.5 gave access to the HomeController instance from a plug-in instance. Then, from the HomeController instance you can access to the other controllers and their views if necessary. If exportToOBJ method doesn't perform like you want, I don't see the problem to write your own method in your plug-in. But if you want to change the behavior of the existing exportToOBJ method, you'll have to create a derived version of Sweet Home 3D, not a plug-in. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 19, 2026, 8:38:00 PM |
