Print at Sep 19, 2026, 8:52:08 PM
Posted by chicosRV at Jun 22, 2012, 7:04:16 PM
Re: use private elements of the classes HomePane and HomeController for made a plugin to export the furniture in separated obj
this is what i have done
i modified the original code of the methods export to obj(it originally exported everything in one obj)
but what i really need is to made that function in a plugin
when a took the code for made the pluggin there were a lot of element that get selected like error
the plugin class only have the home and the userPreferences
this is the code
class Home Controller
public void exportToOBJ() {
final String objName = getView().showExportToOBJDialog(this.home.getName());
final String dir = reduceToRoot(objName);
HomePane.dir = dir;
//Count Furniture//
countFurniture();
writeXMLEden3D("ss");
if (objName != null) {
// Export 3D view in a threaded task
Callable<Void> exportToObjTask = new Callable<Void>() {
public Void call() throws RecorderException {
getView().exportToOBJ(HomePane.dir);
return null;
ThreadedTaskController.ExceptionHandler exceptionHandler =
new ThreadedTaskController.ExceptionHandler() {
public void handleException(Exception ex) {
if (!(ex instanceof InterruptedRecorderException)) {
if (ex instanceof RecorderException) {
String message = preferences.getLocalizedString(
HomeController.class, "exportToOBJError", objName);
getView().showError(message);
} else {
ex.printStackTrace();
new ThreadedTaskController(exportToObjTask,
this.preferences.getLocalizedString(HomeController.class, "exportToOBJMessage"), exceptionHandler,
this.preferences, this.viewFactory).executeTask(getView());
class HomePane
public static void exportHomeToFile(Home home, String objFile, String header) throws RecorderException {
OBJWriter writer = null;
boolean exportInterrupted = false;
String[] names = new String[HomePane.counter];
names[0] = "Room";
int c=1;
for(HomePieceOfFurniture piece : home.getFurniture()) {
if(piece.isVisible()) {
names[c] = piece.getName();
c++;
for(int j=0 ; j < HomePane.counter; j++ ) {
try {
HomePane.objName = names[j];
writer = new OBJWriter(objFile+HomePane.objName+".obj", header, -1);
List<Selectable> emptySelection = Collections.emptyList();
home.setSelectedItems(emptySelection);
if (HomePane.objName.equals("Room"))
if (home.getWalls().size() > 0) {
// Create a not alive new ground to be able to explore its coordinates without setting capabilities
Rectangle2D homeBounds = getExportedHomeBounds(home);
Ground3D groundNode = new Ground3D(home,
(float)homeBounds.getX(), (float)homeBounds.getY(),
(float)homeBounds.getWidth(), (float)homeBounds.getHeight(), true);
writer.writeNode(groundNode, "ground");
// Write 3D walls
int i;
// The first time, we want to export the only the walls and the room
i = 0;
for (Wall wall : home.getWalls()) {
// Create a not alive new wall to be able to explore its coordinates without setting capabilities
Wall3D wallNode = new Wall3D(wall, home, true, true);
writer.writeNode(wallNode, "wall_" + ++i);
// Write 3D rooms
i = 0;
for (Room room : home.getRooms()) {
// Create a not alive new room to be able to explore its coordinates without setting capabilities
Room3D roomNode = new Room3D(room, home, false, true, true);
writer.writeNode(roomNode, "room_" + ++i);
i = 0;
if (!HomePane.objName.equals("Room"))
//Write 3D furniture
for (HomePieceOfFurniture piece : home.getFurniture()) {
if (piece.isVisible() && HomePane.objName.equals(piece.getName())) {
// System.out.printf(objFile + "\n");
// Create a not alive new piece to be able to explore its coordinates without setting capabilities
// I set as home = null
HomePieceOfFurniture3D pieceNode = new HomePieceOfFurniture3D(piece, home, true, true);
writer.writeNode(pieceNode);
catch (InterruptedIOException ex) {
exportInterrupted = true;
throw new InterruptedRecorderException("Export to " + objFile + " interrupted");
} catch (IOException ex) {
throw new RecorderException("Couldn't export to OBJ in " + objFile, ex);
} finally {
if (writer != null) {
try {
writer.close();
// Delete the file if exporting is interrupted
if (exportInterrupted) {
new File(objFile).delete();
