Print at Sep 20, 2026, 5:56:09 AM
Posted by mikeycast at Jun 7, 2012, 8:37:38 PM
Re: Problem using Ant, missing classes
I'll show it from Eclipse if I don't fix it but that's not very serious... I've made a MacOsXInstaller but my panel doesn't launch like at the beginning of this topic (problem you solved in the version 3.5). I've added the 3 lines <string>$JAVAROOT/mysql-connector-java ....jar</string> in the array.
I get the error in the console :
07/06/12 19:28:09,671 [0x0-0x198198].com.eteks.sweethome3d.SweetHome3D: [JavaAppLauncher] Requested [1.5*], launching in [1.6] instead.
It doesn't matter if it is the .jar or an installer, I just would like to launch it without Eclipse sad
I hope it is just a java version problem and that after it will work..
Or even if you can make it work on Windows it will be enough...
Thank you very much
