Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Running in Netbeans; a couple of problems » » » » Post: Re: Running in Netbeans; a couple of problems |
Print at Sep 21, 2026, 6:50:20 PM |
| Posted by Puybaret at May 22, 2012, 10:15:24 AM |
Re: Running in Netbeans; a couple of problems The error you report means the java.ext.dirs property you set didn't work. You have to override the default folders order where extension libraries come from, otherwise Java 3D 1.3.1 installed by default in the system will be picked. Try to change the paths in java.ext.dirs by full paths. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 21, 2026, 6:50:20 PM |
