Print at Sep 21, 2026, 6:48:41 PM
Posted by dtgriscom at May 22, 2012, 5:06:35 AM
Re: Running in Netbeans; a couple of problems
I've already added the libraries individually. I just tried adding "-Djava.ext.dirs=lib:lib/macosx" (no quotes) to the Netbeans project's Run/VM Options value, but I still get the same error (even after restarting Netbeans).
The error is kind of strange, since everything else is present, including the javax.media.j3d.RenderingErrorListener class, which (AFAIK) is only used by the apparently missing method.
I threw in a piece of code at the beginning of the com.eteks.sweethome3d.SweetHome3D.main() method:
Properties p = System.getProperties();
Enumeration keys = p.keys();
while (keys.hasMoreElements()) {
String key = (String)keys.nextElement();
String value = (String)p.get(key);
System.out.println(key + ": " + value);
and then ran, and got the following output:
Have no file for /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/jsfd.jar
Have no file for /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/laf.jar
Have no file for /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/sunrsasign.jar
java.runtime.name: Java(TM) SE Runtime Environment
sun.boot.library.path: /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries
java.vm.version: 20.6-b01-415
awt.nativeDoubleBuffering: true
gopherProxySet: false
mrj.build: 10M3635
java.vm.vendor: Apple Inc.
java.vendor.url: http://www.apple.com/
path.separator: :
java.vm.name: Java HotSpot(TM) 64-Bit Server VM
file.encoding.pkg: sun.io
sun.java.launcher: SUN_STANDARD
user.country: US
sun.os.patch.level: unknown
java.vm.specification.name: Java Virtual Machine Specification
user.dir: /Users/griscom/Documents/Projects/Random/SweetHome3D
java.runtime.version: 1.6.0_31-b04-415-10M3635
java.awt.graphicsenv: apple.awt.CGraphicsEnvironment
java.endorsed.dirs: /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/lib/endorsed
os.arch: x86_64
java.io.tmpdir: /var/folders/0n/0nlYD3RaGQy+7gJ8C72wKk+++TI/-Tmp-/
line.separator:
java.vm.specification.vendor: Sun Microsystems Inc.
os.name: Mac OS X
sun.jnu.encoding: MacRoman
java.library.path: .:/Users/griscom/Library/Java/Extensions:/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java
java.specification.name: Java Platform API Specification
java.class.version: 50.0
sun.management.compiler: HotSpot 64-Bit Tiered Compilers
os.version: 10.6.8
http.nonProxyHosts: local|*.local|169.254/16|*.169.254/16
user.home: /Users/griscom
user.timezone:
java.awt.printerjob: apple.awt.CPrinterJob
file.encoding: UTF-8
java.specification.version: 1.6
java.class.path: /Users/griscom/Documents/Projects/Random/SweetHome3D/SweetHome3D-3.5-src/lib/batik-svgpathparser-1.7.jar
:/Users/griscom/Documents/Projects/Random/SweetHome3D/SweetHome3D-3.5-src/lib/freehep-vectorgraphics-svg-2.1.1.jar
:/Users/griscom/Documents/Projects/Random/SweetHome3D/SweetHome3D-3.5-src/lib/iText-2.1.7.jar
:/Users/griscom/Documents/Projects/Random/SweetHome3D/SweetHome3D-3.5-src/lib/j3dcore.jar
:/Users/griscom/Documents/Projects/Random/SweetHome3D/SweetHome3D-3.5-src/lib/j3dutils.jar
:/Users/griscom/Documents/Projects/Random/SweetHome3D/SweetHome3D-3.5-src/lib/jmf.jar
:/Users/griscom/Documents/Projects/Random/SweetHome3D/SweetHome3D-3.5-src/lib/Loader3DS1_2u.jar
:/Users/griscom/Documents/Projects/Random/SweetHome3D/SweetHome3D-3.5-src/lib/sunflow-0.07.3g.jar
:/Users/griscom/Documents/Projects/Random/SweetHome3D/SweetHome3D-3.5-src/lib/vecmath.jar
:/Users/griscom/Documents/Projects/Random/SweetHome3D/SweetHome3D-3.5-src/libtest/abbot.jar
:/Users/griscom/Documents/Projects/Random/SweetHome3D/SweetHome3D-3.5-src/libtest/AppleJavaExtensions.jar
:/Users/griscom/Documents/Projects/Random/SweetHome3D/SweetHome3D-3.5-src/libtest/gnu-regexp-1.1.0.jar
:/Users/griscom/Documents/Projects/Random/SweetHome3D/SweetHome3D-3.5-src/libtest/jdepend-2.9.jar
:/Users/griscom/Documents/Projects/Random/SweetHome3D/SweetHome3D-3.5-src/libtest/jdom-1.0.jar
:/Users/griscom/Documents/Projects/Random/SweetHome3D/SweetHome3D-3.5-src/libtest/jnlp.jar
:/Users/griscom/Documents/Projects/Random/SweetHome3D/SweetHome3D-3.5-src/libtest/profile.jar
:/Users/griscom/Documents/Projects/Random/SweetHome3D/build/classes
user.name: griscom
java.vm.specification.version: 1.0
sun.java.command: com.eteks.sweethome3d.SweetHome3D
java.home: /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home
sun.arch.data.model: 64
user.language: en
java.specification.vendor: Sun Microsystems Inc.
awt.toolkit: apple.awt.CToolkit
java.vm.info: mixed mode
java.version: 1.6.0_31
java.ext.dirs: lib:lib/macosx
sun.boot.class.path: /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/jsfd.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/classes.jar
:/System/Library/Frameworks/JavaVM.framework/Frameworks/JavaRuntimeSupport.framework/Resources/Java/JavaRuntimeSupport.jar
:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/ui.jar
:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/laf.jar
:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/sunrsasign.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/jsse.jar
:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/jce.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/charsets.jar
java.vendor: Apple Inc.
file.separator: /
java.vendor.url.bug: http://bugreport.apple.com/
sun.io.unicode.encoding: UnicodeLittle
sun.cpu.endian: little
mrj.version: 1060.1.6.0_31-415
socksNonProxyHosts: local|*.local|169.254/16|*.169.254/16
ftp.nonProxyHosts: local|*.local|169.254/16|*.169.254/16
sun.cpu.isalist:
Exception in thread "main" java.lang.NoClassDefFoundError: javax/media/opengl/GLCapabilitiesChooser
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631)
at java.lang.ClassLoader.defineClass(ClassLoader.java:615)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:283)
at java.net.URLClassLoader.access$000(URLClassLoader.java:58)
at java.net.URLClassLoader$1.run(URLClassLoader.java:197)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:169)
at javax.media.j3d.Pipeline$1.run(Pipeline.java:162)
at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:157)
at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:965)
at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:299)
at javax.media.j3d.GraphicsConfigTemplate3D.getBestConfiguration(GraphicsConfigTemplate3D.java:321)
at java.awt.GraphicsDevice.getBestConfiguration(GraphicsDevice.java:159)
at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Component3DManager.java:65)
at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Component3DManager.java:100)
at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(SweetHome3D.java:500)
at com.eteks.sweethome3d.SweetHome3D.init(SweetHome3D.java:392)
at com.eteks.sweethome3d.SweetHome3D.main(SweetHome3D.java:296)
Caused by: java.lang.ClassNotFoundException: javax.media.opengl.GLCapabilitiesChooser
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
... 26 more
... any ideas?
Thanks,
Dan
[Note from moderator: cut long lines in code section]
