Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: BUG: Persistent background image on file after deletion » » » » Post: Re: BUG: Persistent background image on file after deletion |
Print at Sep 6, 2026, 10:28:42 AM |
| Posted by hal9000 at May 9, 2012, 9:29:17 PM |
Re: BUG: Persistent background image on file after deletion Oh, I see. Mystery solved then. Certainly I created additional levels which I removed when I deleted all the content, leaving only the first level with the background image. I hope it can be fixed easily. It's not a big problem, but it's more annoying when the imported background image has a large size, like the one I used. Puybaret, if for some reason the fixing implies many or complex changes, I guess at least you could make a simple substitution of the actual image file for a dummy image file (0 bytes or 1x1 pixels), that way the wasted space is released. Thanks and regards. ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
Current timezone is GMT Sep 6, 2026, 10:28:42 AM |
