Print at Sep 20, 2026, 6:50:57 AM
Posted by danielfranklinr at Apr 9, 2012, 4:46:40 AM
Preload Structure Plans
Hello everyone.
I got some other questions and i was hoping that you could give me some bearings to get to the answers.
I was thinking in the possibility to add some preloaded plans of rooms in the application so that the users could have some starting points when they begin to design their plans.
I made up some cuts and slices through the code and reached the Furniture Catalog Pane and a bit later to the class CatalogPieceOfFurniture, but the info it contains is pretty specific to furnitures.
The only solution i'm thinking of is to create a whole new Panel for the plans. Do you think is possible at all? Has anyone worked on this?
The other question i have is a lot trickier for what i managed to see in the code. Does anyone tried to add a button to make the dimensions of walls show in the PlanPane. Any hints in this?
Finally, i read in another post that the UML diagrams posted are not updated, is there any diagram updated? confused
Thanks for the help in advance!.
