Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: problem with import and texture problem » » » » Post: Re: problem with import and texture problem |
Print at Sep 6, 2026, 12:41:28 PM |
| Posted by Puybaret at Mar 29, 2012, 9:15:14 PM |
Re: problem with import and texture problem You should check how you exported your model from the modeler you use. First the faces are inverted, something you can fix with the check box at the second step of the import furniture wizard. Then, maybe you didn't generate texture coordinates or files have incorrect names (avoid spaces). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 12:41:28 PM |
