Print at Sep 20, 2026, 3:25:46 PM
Posted by coldcomfort at Mar 29, 2012, 2:54:41 PM
Re: roof window
@peter. I'm not sure what problem you're facing now but the procedure is pretty simple:
-build the walls in the shape you want for the roof (one panel, two angled panels or even 3 with the middle one flat, as a roof window);
-insert the window in the walls at the right position and change its size accordingly;
-choose the color/texture for the inside and outside (roof tile texture) walls.
-select it and choose 'copy as new furniture' from tools menu (assuming you installed the "copy as new furniture' plugin http://www.sweethome3d.com/pluginsUserGuide.pdf );
-after you paste the new object and delete the old one, 'export to OBJ format' from the 3D window;
Now you should be able to import it as new furniture and rotate it as you need.
