Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to use snap / grid » » » » Post: Re: How to use snap / grid |
Print at Sep 20, 2026, 5:29:05 AM |
| Posted by hansmex at Feb 28, 2012, 1:31:24 PM |
Re: How to use snap / grid Mike, The grid in SH3D has no other function than to act as a visual guide. There's no Snap to feature. If you want exact measures you will need to enter them manually: 1 - Draw your first line manually, then use Modify walls to correct the X,Y coordinates. 2 - For consecutive lines you can set the starting point by using the built-in magnetism, which shows connections at end points, and also at left, right and middle of the wall. 3 - To draw more, consecutive points of connected walls, you can hit the Enter key on your keyboard. This brings up a small dialogue box that allows you to exactly enter the length, angle and thickness of the wall. 4 - To join unconnected endpoints of two walls, you can use the plug-in AdvancedEdit (PDF), which provides the new function Plan -> Connect walls. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 20, 2026, 5:29:05 AM |
