Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Crash while making a 3D photo quality 3 and 4 » » » » Post: Re: Crash while making a 3D photo quality 3 and 4 |
Print at Sep 6, 2026, 8:52:20 AM |
| Posted by hansmex at Feb 18, 2012, 6:08:32 PM |
Re: Crash while making a 3D photo quality 3 and 4 Christine, If the crash happens only with one file, then there are two possibilities (as far as I know): 1 - The file is corrupt. (not so likely) Try to open and save it, to check if the file is OK. If it's OK, try to make a render. 2 - There is a problematic piece of furniture in your design. (most likely) I suggest you delete all furniture (or make it invisible) and try to make a render. If you can make a render now, it's time to find the offending piece of furniture. Delete half of your furniture (or make it invisible) and try to make a render. If you can make a render, the problem lies in the other half of your models. Continue this process to narrow down which model is the culprit. Try groups of 10 or 20 models at a time, depending on how many models there are in your design. Standard models are unlikely to cause crashes. Most likely it's an imported model (DAE or 3DS are excellent candidates). Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 6, 2026, 8:52:20 AM |
