Print at Sep 19, 2026, 7:17:34 PM
Posted by Mitsaki at Jan 20, 2012, 6:08:46 PM
Re: How to export to .obj all furniture seperately.
So, what I finally did and it worked is:
I first added in the HomePane.java
// Used in the export
public static int m = 0;
public static int o = 0;
public static String a;
public static String objFile
Afterwards, I changed the HomeController.java and especially exporttoObj
public void exportToOBJ() {
// Added from this point...
// In the beginning k=0, l=0, m=0
// Count how many pieces of furniture are placed in the house during the first control
//-------------------------------COUNT THE FURNITURE------------------------------------
HomePane.m = 0;
HomePane.objFile = "";
for (HomePieceOfFurniture piece : home.getFurniture()) {
if (piece.isVisible()) {
// In the end m shows how many furniture there are
HomePane.m++;
// I add one, so that I can store "Room" in it.
HomePane.m = HomePane.m + 1;
System.out.printf (HomePane.m + "\n");
//------------------------------------SAVE THE ARRAY------------------------------------
// A table used to save the names of the furniture with the "m" that we counted before
String [] temp = new String[HomePane.m + 1];
temp[0] = "Room";
HomePane.o = 1;
temp[HomePane.o] = piece.getName();
//System.out.printf (HomePane.o + "\n");
// System.out.printf(temp[HomePane.o] + "\n");
HomePane.o++;
String [] Furniture = new String[HomePane.m];
int z;
for (z = 0; z < HomePane.m ; z++)
Furniture[z] = temp[z];
// l is used for the array Furniture[m] and it will be used again
HomePane.o = 0;
// For the room
//-----------------------------------CALL THE FUNCTION----------------------------------
for (HomePane.o = 0; HomePane.o < HomePane.m ; HomePane.o++)
// System.out.printf (HomePane.o + "\n");
// System.out.printf(Furniture[HomePane.o] + "\n");
HomePane.a = Furniture[HomePane.o];
HomePane.objFile = Furniture[HomePane.o];
// System.out.printf(objFile + "\n");
// Use a clone of home to ignore selection
final String objName = getView().showExportToOBJDialog(this.home.getName());
if (objName != null) {
// Export 3D view in a threaded task
Callable<Void> exportToObjTask = new Callable<Void>() {
public Void call() throws RecorderException {
getView().exportToOBJ(objName);
return null;
ThreadedTaskController.ExceptionHandler exceptionHandler =
new ThreadedTaskController.ExceptionHandler() {
public void handleException(Exception ex) {
if (!(ex instanceof InterruptedRecorderException)) {
if (ex instanceof RecorderException) {
String message = preferences.getLocalizedString(
HomeController.class, "exportToOBJError", objName);
getView().showError(message);
} else {
ex.printStackTrace();
new ThreadedTaskController(exportToObjTask,
this.preferences.getLocalizedString(HomeController.class, "exportToOBJMessage"), exceptionHandler,
this.preferences, this.viewFactory).executeTask(getView());
and then I changed the HomePane.java and especially private static class OBJExporter
private static class OBJExporter {
public static void exportHomeToFile(Home home, String objFile, String header) throws RecorderException {
OBJWriter writer = null;
boolean exportInterrupted = false;
try {
writer = new OBJWriter(objFile, header, -1);
if (objFile.equals("./My_Home/Room.obj"))
List<Selectable> emptySelection = Collections.emptyList();
home.setSelectedItems(emptySelection);
if (home.getWalls().size() > 0) {
// Create a not alive new ground to be able to explore its coordinates without setting capabilities
Rectangle2D homeBounds = getExportedHomeBounds(home);
Ground3D groundNode = new Ground3D(home,
(float)homeBounds.getX(), (float)homeBounds.getY(),
(float)homeBounds.getWidth(), (float)homeBounds.getHeight(), true);
writer.writeNode(groundNode, "ground");
// Write 3D walls
int i;
// The first time, we want to export the only the walls and the room
i = 0;
System.out.printf("Bhka sto walls\n");
for (Wall wall : home.getWalls()) {
// Create a not alive new wall to be able to explore its coordinates without setting capabilities
Wall3D wallNode = new Wall3D(wall, home, true, true);
writer.writeNode(wallNode, "wall_" + ++i);
// Write 3D rooms
i = 0;
for (Room room : home.getRooms()) {
System.out.printf("Bhka sto Room\n");
// Create a not alive new room to be able to explore its coordinates without setting capabilities
Room3D roomNode = new Room3D(room, home, false, true, true);
writer.writeNode(roomNode, "room_" + ++i);
i = 0;
if (!objFile.equals("./My_Home/Room.obj"))
System.out.printf("Bhka sto Furniture1\n");
//Write 3D furniture
if (piece.isVisible() && objFile.equals("." + File.separator + "My_Home" + File.separator + piece.getName() + ".obj")) {
System.out.printf("Bhka sto Furniture2\n");
// Create a not alive new piece to be able to explore its coordinates without setting capabilities
// I set as home = null
HomePieceOfFurniture3D pieceNode = new HomePieceOfFurniture3D(piece, home, true, true);
writer.writeNode(pieceNode);
} catch (InterruptedIOException ex) {
exportInterrupted = true;
throw new InterruptedRecorderException("Export to " + objFile + " interrupted");
} catch (IOException ex) {
throw new RecorderException("Couldn't export to OBJ in " + objFile, ex);
} finally {
if (writer != null) {
try {
writer.close();
// Delete the file if exporting is interrupted
if (exportInterrupted) {
new File(objFile).delete();
That's more or less it.
