Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Issue while transferring a .sh3d file » » » » Post: Re: Issue while transferring a .sh3d file |
Print at Sep 25, 2026, 9:44:04 AM |
| Posted by Puybaret at Jan 12, 2012, 1:31:50 PM |
Re: Issue while transferring a .sh3d file As SH3D files are fully compatible across operating systems, this has probably nothing to do with a memory problem or a Linux 64bits vs a a Windows 32 bits box, but it must be a issue related to the fact that the file wasn't transferred/copied correctly. The minimum check would to compare files size? Can you check they are the same? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 25, 2026, 9:44:04 AM |
