Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Access the PlanController » » » » Post: Re: Access the PlanController |
Print at Sep 19, 2026, 7:16:06 PM |
| Posted by Puybaret at Jan 5, 2012, 12:14:39 PM |
Re: Access the PlanController Hi, I just committed some changes in source code to grant access to controllers from plugins. Sorry if I didn't include this change in version 3.4, but once I discovered that it required to change some dependency between com.eteks.sweethome3d.viewcontroller and com.eteks.sweethome3d.plugin packages, I was reluctant to do it, because it would break code in some versions derived from Sweet Home 3D (but not existing plugins). I finally made the changes today, so please test it when you can. To all developers who created a derived version of Sweet Home 3D: if your program uses directly com.eteks.sweethome3d.viewcontroller.HomeController class (by subclassing it or instantiating it), you should just replace it by com.eteks.sweethome3d.plugin.HomePluginController class. Sorry for any problem it might cause. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 19, 2026, 7:16:06 PM |
