Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: 3D Models - Need Help! » » » » Post: Re: 3D Models - Need Help! |
Print at Sep 20, 2026, 10:17:52 AM |
| Posted by hansmex at Dec 28, 2011, 1:17:44 PM |
Re: 3D Models - Need Help! Vako, There are a few known problems with importing furniture. Furniture in DAE (or ZIP) format, taken from the Sketchup Warehouse store their textures in a separate directory. When you change the directory for the furniture, you should also move the directory with the textures to the same place, otherwise the model will appear gray because the textures cannot be found. Models in 3DS format may suffer also from being gray. Here the solution is not so simple. Sometimes it helps to import and export the model using Blender. When models appear as a dot, they are probably too small. This is caused by a difference in measure system. If created in millimeters and imported in meters, your models will appear like little dots. The solution is too multiply the size with 1000 during importation. Inches and centimeters means that you should multiply with 2.54. I hope this solves the problem. If not, share a model that gives you problems, so that we can have a look at it. I'm not sure I understand your problem with textures. Can you explain better, or email me texture that is causing you problems? Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 20, 2026, 10:17:52 AM |
