Print at Sep 19, 2026, 6:49:10 PM
Posted by Alex42 at Dec 26, 2011, 5:35:35 PM
confused   how to add package resource bundles?
what's the correct way to add a package resource (package.properties) bundle from inside a plugin to the UserPreferences in a way that a panel (defined inside the plugin) can access the bundle?
As far as I've seen the plugin's classloader is not registered and therefore not returned from UserPreferences#getResourceClassLoaders(). But adding it to this list does not solve the issue as the used class is FileUserPreferences and this owns a list of classloaders by its own which is initialized only inside updateSupportedLanguages() which is private and not called after all the plugins were loaded. :-(
If there's no way to register a plugin's classloader to resolve resources correctly the attached patch would solve the issue. (Hope that I'm able to attach a file as I do not see any way right now confused)
Regards,
Alex
