Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: flickering textures on self-created models » » » » Post: Re: flickering textures on self-created models |
Print at Sep 9, 2026, 8:37:44 PM |
| Posted by hansmex at Dec 6, 2011, 12:14:59 PM |
Re: flickering textures on self-created models José, The culprits are two DAE models whose faces aren't oriented properly names begin with "linka"). This should be solved within Sketchup. I'll try to explain how to do this: - select your model - right-click and select Explode - if necessary, repeat several times until the object is "deconstructed" into its smallest elements - now select one or more visible parts of the model; the selected face is now dotted blue - while selected, right-click and select Reverse Faces Within Sketchup you most probably won't see any difference. Now export your model again, and import it in SH3D. If all went well, SH3D now interprets the orientation of the faces in the correct manner, and you won't see the flickering. There are a few plug-ins for Sketchup that may (or may not) do this automatically: - automatic face reverser - reverse faces I hope this solves the problem. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 9, 2026, 8:37:44 PM |
