Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Duplicating object will not release the cursor » » » » Post: Re: Duplicating object will not release the cursor |
Print at Aug 24, 2026, 5:27:25 PM |
| Posted by node105 at Nov 20, 2011, 11:46:19 PM |
Re: Duplicating object will not release the cursor <<it's actually a memory problem. Even if you might find that weird,>> I do; it has been a very long time since I last had to reset a memory value As I indicated, it is not only this model, but was another much smaller ( just can't recall which one). Not as issue discarding the particular model I am well used to flaky Java; as a filemaker developer server user Actually 2 places in the .plist, and the existing value is not as the fq indicates (i.e. is not 1024) <key>Properties</key> <dict> <key>apple.awt.graphics.UseQuartz</key> <string>true</string> <key>apple.laf.useScreenMenuBar</key> <string>true</string> <key>jnlpx.heapsize</key> <string>NULL,536870912</string> <key>jnlpx.offline</key> <string>true</string> </dict> <key>VMOptions</key> <array> <string>-Xmx536870912</string> </array> THanks |
Current timezone is GMT Aug 24, 2026, 5:27:25 PM |
