Sweet Home 3D Forum » List all forums » » Forum: Forum in other languages » » » Thread: Import von 3ds aus 3dsMax ohne die richtigen Farben » » » » Post: Re: Import von 3ds aus 3dsMax ohne die richtigen Farben |
Print at Oct 6, 2026, 1:53:36 AM |
| Posted by sclee at Oct 14, 2011, 7:09:17 AM |
Re: Import von 3ds aus 3dsMax ohne die richtigen Farben Try in "3ds max" 1.export>export>save name>Force black ambient>v >Mapexport>use map-path,select path. 2.Flip YZ-axis> v. 3.force>select trianges. 4.export If an error occurs when you export, you must identify the path to texture, store will be active. It was the "3ds Max" save path, not a "Sweet Home 3D" OBJ problem. |
Current timezone is GMT Oct 6, 2026, 1:53:36 AM |
