Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: 3D preview no longer centered » » » » Post: Re: 3D preview no longer centered |
Print at Sep 24, 2026, 12:07:02 PM |
| Posted by Puybaret at Oct 11, 2011, 7:13:39 AM |
Re: 3D preview no longer centered In aerial view mode, the view is centered on the middle of everything you added to the plan (furniture, walls, rooms...). So either you created a big outside room for the garden for example and you should reduce its size, or you added a small item (furniture or wall) in the plan that you don't see at the scale you use. In the later case, the easiest to find it is to select Edit > Select all menu item and zoom out. Once you found the zone where it is, click on it to select it alone and delete it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 12:07:02 PM |
