Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: print on pdf does not work in my linux box » » » » Post: Re: print on pdf does not work in my linux box |
Print at Sep 24, 2026, 2:24:29 AM |
| Posted by ChrisOfBristol at Oct 9, 2011, 9:11:54 PM |
Re: print on pdf does not work in my linux box Hans I'm a bit confused about what you are recommending, perhaps I don't understand the terminology. Your statement (1) suggested that the Software Centre was used to install the program, whereas (2) suggested that you just downloaded the program. I never use the Java Web Start version, I couldn't make that work so don't use it. but always the installed version (1) When I use the Ubuntu Software Centre or your link it doesn't work. I then download and unzip SH3D in its own directory (2) As mentioned above, this is what I am using, although I haven't unzipped the .jar file. I can then start the program by double-clicking SweetHome3D, a shell script of 771 bytes. I could not find a shell script. I use java -Dcom.eteks.sweethome3d -jar /home/user/Documents/SweetHome3D/SweetHome3D-3.3.jar I hope this clarifies my confusion - if you see what I mean! Chris |
Current timezone is GMT Sep 24, 2026, 2:24:29 AM |
