Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: print on pdf does not work in my linux box » » » » Post: Re: print on pdf does not work in my linux box |
Print at Sep 24, 2026, 2:24:14 AM |
| Posted by hansmex at Oct 8, 2011, 9:22:58 PM |
Re: print on pdf does not work in my linux box Chris, In the past, before U-11.04, I've had some problems as well. When I install SH3D, I never use the Java Web Start version, but always the installed version. In my case the 64 bit version. I first delete or uninstall all Java versions. I then download and unzip SH3D in its own directory. I can then start the program by double-clicking SweetHome3D, a shell script of 771 bytes. When you open the script with gedit, you will see that it defines or loads a lot of things. What may be of interest to you is -Xmx????m. This sets the amount of memory SH3D can use. If you have enough memory, you could set it to -Xmx2048m. This may solve the problem you encounter when creating videos. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 24, 2026, 2:24:14 AM |
