Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: My first home using sweet home 3D! » » » » Post: Re: My first home using sweet home 3D! |
Print at Sep 20, 2026, 12:48:59 PM |
| Posted by devilbliss at Sep 26, 2011, 7:40:43 AM |
Re: My first home using sweet home 3D! Dan, what I did is to save the picture frame furniture to obj format. After that, go to the file folder where you saved the furniture, you would see another file with PNG extension. Then, select a picture that you would like to use and change the file extension to ".png" and copy it to the folder where you saved your obj file. Go back to the folder where you saved your obj then find the png file and copy it's filename, rename the new picture that you would like to use with the copied filename and delete the old one. Try exporting the obj file in sweet home 3d. This also applies to walls and floors but the picture is tiled. |
Current timezone is GMT Sep 20, 2026, 12:48:59 PM |
