Print at Sep 19, 2026, 5:41:03 PM
Posted by Mitsaki at Aug 21, 2011, 7:37:24 PM
confused   Re: How to run a new class in SH3D source
The thing is that I was expecting to have something created, a wall, a room...
but nothing is displayed.
Here is the code, after the changes.
package com.eteks.sweethome3d;
import java.beans.PropertyChangeEvent;
import java.beans.PropertyChangeListener;
import java.io.BufferedReader;
import java.io.DataInputStream;
import java.io.FileInputStream;
import java.io.InputStreamReader;
import java.util.ArrayList;
import java.util.List;
import com.eteks.sweethome3d.model.CollectionEvent;
import com.eteks.sweethome3d.model.CollectionListener;
import com.eteks.sweethome3d.SweetHome3D;
import com.eteks.sweethome3d.model.Home;
import com.eteks.sweethome3d.model.Room;
import com.eteks.sweethome3d.model.Wall;
public class Blender extends SweetHome3D {
public static String[] str = new String[108];
public static String Shape_of_Room = str[2];
public static String Shiny_Matt = str[3];
public static String Right_Wall_Color = str[5];
public static String Right_Wall_Texture = str[6];
public static String Left_Wall_Color = str[7];
public static String Left_Wall_Texture = str[8];
public static String North_Wall_Color = str[9];
public static String North_Wall_Texture = str[10];
public static String South_Wall_Color = str[11];
public static String South_Wall_Texture = str[12];
public static String Ceiling_Display = str[13];
public static String Ceiling_Texture = str[14];
public static String Floor_Display = str[15];
public static String Floor_Texture = str[16];
public static String[] List_of_Furniture;
public static void main(String [] args) {
// First save the furniture in an array
// Maximum elements of the array:108 (91 obligatory, 88 optional)
int j;
// Declare the size of the List_of_Furniture
List_of_Furniture = new String[92];
for (j=0;j<91;j++) {
List_of_Furniture[j] = str[j+17];
try {
// Open the file that is the first
// command line parameter
FileInputStream fstream = new FileInputStream("/Users/dimitramicha/Desktop/SweetHome3D1.txt");
// Get the object of DataInputStream
DataInputStream in = new DataInputStream(fstream);
BufferedReader br = new BufferedReader(new InputStreamReader(in));
String strLine;
// Read File Line By Line
int i=0;
while ((strLine = br.readLine()) != null)
// Print the content on the console
System.out.println (strLine);
System.out.println(i);
str = strLine;
System.out.println(str);
i++;
// Check each line - Don't forget to make them comments afterwards!!!!!
// Close the input stream
in.close();
catch (Exception e)
// Catch exception if any
System.err.println("Error: " + e.getMessage());
// Run the application SweetHome3D and run method createHome()
Blender blender = new Blender();
blender.init(args);
blender.createHome();
// The ability of a subclass to override a method allows a class to inherit from
// a superclass whose behavior is "close enough" and then to modify behavior as needed.
// The overriding method has the same name, number and type of parameters, and return type
// as the method it overrides. An overriding method can also return a subtype of the type
// returned by the overridden method.
@Override
public Home createHome() {
Home home = super.createHome();
if (Shape_of_Room=="Parallelogram")
// Create a home and a wall listener that updates lists when notified
Home Parallelogram = new Home();
// Create a Room - Room (float[][] points)
// Any of these numbers can be followed by "F" (or "f")
// to make it a float instead of the default double
float[][] points = {{0f,0f},{0f,400f},{625f,400f},{625f,400f},{625f,0f},{0f,0f}};
Room Parallelogram_Room = new Room(points);
Parallelogram_Room.setAreaVisible(true);
// Add new Room to Home
Parallelogram.addRoom(Parallelogram_Room);
// Notify Listeners
final List<Wall> addedWalls = new ArrayList<Wall>();
final List<Wall> deletedWalls = new ArrayList<Wall>();
final List<Wall> updatedWalls = new ArrayList<Wall>();
final PropertyChangeListener wallChangeListener = new PropertyChangeListener()
public void propertyChange(PropertyChangeEvent ev)
updatedWalls.add((Wall)ev.getSource());
Parallelogram.addWallsListener(new CollectionListener<Wall> ()
public void collectionChanged(CollectionEvent<Wall> ev)
switch (ev.getType())
case ADD :
addedWalls.add(ev.getItem());
ev.getItem().addPropertyChangeListener(wallChangeListener);
break;
case DELETE :
deletedWalls.add(ev.getItem());
ev.getItem().removePropertyChangeListener(wallChangeListener);
break;
//Creation Walls
Wall Left_Wall = new Wall(0, 0, 0, 400, (float) 7.62);
Wall North_Wall = new Wall(0, 400, 625, 400, (float) 7.62);
Wall Right_Wall = new Wall(625, 400, 625 ,0 , (float) 7.62);
Wall South_Wall = new Wall(625, 0, 0, 0, (float) 7.62);
// Add them to home
Parallelogram.addWall(Left_Wall);
Parallelogram.addWall(North_Wall);
Parallelogram.addWall(Right_Wall);
Parallelogram.addWall(South_Wall);
// Set as User Preferences the default User Preferences
//UserPreferences preferences = new DefaultUserPreferences();
// Set as Texture image the first texture that is available
//TextureImage firstTexture = preferences.getTexturesCatalog().getCategories().get(0).getTexture(0);
// Join end point of one wall to start point of the other wall (4 times - 4 walls)
Left_Wall.setWallAtEnd(North_Wall);
North_Wall.setWallAtEnd(Right_Wall);
Right_Wall.setWallAtEnd(South_Wall);
South_Wall.setWallAtEnd(Left_Wall);
if (Shape_of_Room == "Square") {
Home Square = new Home();
if (Shape_of_Room == "Trapeze-1") {
Home Trapeze_1 = new Home();
if (Shape_of_Room == "Trapeze-2") {
Home Trapeze_2 = new Home();
// Modify home as you wish here
return home;
