Print at Sep 21, 2026, 6:17:21 AM
Posted by Puybaret at Jul 30, 2011, 12:28:41 PM
Re: How can I access auto recovery files? I just lost all of my work!
Thanks for the information. This is the information I need, but as I can't view the screenshot you posted, I would be also pleased to read the lines following:
at java.util.zip.ZipInputStream.getNextEntry(ZipInputStream.java:73)
From this first part, you must be using a 3D model with non ASCII characters or wrongly encoded characters, or your SH3D file is wrong, and from Java sources, there were some changes from Java 1.5 to Java 1.6 about this possible problem. If you run Sweet Home 3D under Java 1.6, it may have worked or if it failed, an error dialog would have appeared at least.
Then I guess you run Sweet Home 3D under Java 1.5 (see About Sweet Home 3D dialog box), right? What Mac OS X version are you running?
Can you send me your buggy file, so I check myself?
