Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Multi mirror plan » » » » Post: Re: Multi mirror plan |
Print at Sep 27, 2026, 9:53:34 AM |
| Posted by Puybaret at Jun 16, 2011, 10:00:35 AM |
Re: Multi mirror plan The OBJ files interpreter of Sweet Home 3D doesn't display the material colors you chose because Sketchup didn't create a new object with a line starting by g or o, for each color or texture change happening with a line starting by usemtl. As there doesn't seem to be any OBJ export option in Sketchup that would say "Separate by color" or "Separate by material", I guess I'll have to update Sweet Home 3D... At this time, I would: - export the 3D model in DAE/Collada file format from Sketchup, - import the DAE file in an empty home in Sweet Home 3D, - export it with 3D view > Export to OBJ format menu item, - change in the generated OBJ file the name in each g line preceding the usemtl matching a mirror material, with something prefixed by sweethome3d_window_mirror, - import the modified OBJ file in Sweet Home 3D again. Hope this is clear enough... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 27, 2026, 9:53:34 AM |
