Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: method to print design with grids » » » » Post: Re: method to print design with grids |
Print at Sep 21, 2026, 7:51:59 AM |
| Posted by Puybaret at May 25, 2011, 1:05:03 PM |
Re: method to print design with grids Thanks for the tip... even if Photoshop license might be too much expensive for such a need. Remember also that exporting to SVG then importing + adding a grid with Inkscape might give better results since the plan will be in vector graphics. By the way, if you want the grid in the Sweet Home 3D itself, you could also use this older tip. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 21, 2026, 7:51:59 AM |
