Print at Sep 19, 2026, 8:31:44 PM
Posted by hansmex at May 20, 2011, 8:15:20 AM
Re: How to make yellow colored 3d view at floor planner
Rahul,
The standard colour for walls, floors and ceilings is light gray. There is no way to change this from within the program.
If it is important to you, you can try to change the program code of SH3D. The source code is publicly available. And of course, you can ask Puybaret to point you in the right direction.
A fast way to change all walls or rooms is to select your entire design with CTRL-A, then right-click and select Modify walls or Modify rooms.
