Print at Sep 11, 2026, 6:34:22 AM
Posted by hansmex at May 12, 2011, 6:27:21 PM
Re: reconnect split walls
Marshall,
1 - Connect two walls
If you install the AdvancedEdit plug-in (see manual PDF) you can connect two walls, giving them an "elastic" connection. Corners will be closed, and if necessary beveled.
2 - (Re-)Connect split walls
A split wall is still connected (see 1). You cannot make one continuous wall from two wall sections. Once a wall is split, it cannot be re-joined.
