Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Sweethome3d+Xinerama+4Screen+2GPU Setup? » » » » Post: Sweethome3d+Xinerama+4Screen+2GPU Setup? |
Print at Sep 6, 2026, 11:32:26 AM |
| Posted by MaDDeePee at May 10, 2011, 7:11:45 PM |
Sweethome3d+Xinerama+4Screen+2GPU Setup?Hi guys, im unable to start Sweethome 3D with Xinerama enabled. Im running a Xinerama setup bound with 2 Nvidia Gfx and 4 Screens connected. (Geforce GT520 & GTX560ti) Whenever i try to start Sweethome3d, this happens:
# # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0x6d69d880, pid=1522, tid=1821494128 # # JRE version: 6.0_24-b07 # Java VM: Java HotSpot(TM) Server VM (19.1-b02 mixed mode linux-x86 ) # Problematic frame: # C [libnvidia-glcore.so.270.41.06+0xc8d880] # # An error report file with more information is saved as: # /home/maddeepee/hs_err_pid1522.log # # If you would like to submit a bug report, please visit: # http://java.sun.com/webapps/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. # Abgebrochen maddeepee@MaDWorkStatioN ~ $ I'm already using newest Gfx drivers and also tested older ones, without success. DISABLING Xinerama make me able to use that program. So....is this a xinerama or Nvidia related problem? Does i have to post the logfiles or is my problem located with that output? Yours :) |
Current timezone is GMT Sep 6, 2026, 11:32:26 AM |
