Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: texture bug » » » » Post: Re: texture bug |
Print at Sep 6, 2026, 10:20:22 AM |
| Posted by hansmex at May 6, 2011, 9:16:00 AM |
Re: texture bug rino, The texture renders fine every time: I tried at least 20 times without any problem. I suggest you follow Puybarets suggestion: - move a wall to check that there aren't two walls on top of each other - if two walls are on top, delete one wall - if not, move the wall back with Undo - go to the next wall - if you find a double wall, make a few renders to check if this solves the problem. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 6, 2026, 10:20:22 AM |
