Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SH3D 3.2 crashes under Ubuntu 11.04 » » » » Post: Re: SH3D 3.2 crashes under Ubuntu 11.04 |
Print at Sep 6, 2026, 10:20:39 AM |
| Posted by hansmex at Apr 28, 2011, 4:26:20 PM |
Re: SH3D 3.2 crashes under Ubuntu 11.04 Emmanuel, The plot thickens... Trying to solve my problems, I tried webstart v3.2, something I normally don't use. The first time the program ran just fine: I could insert a model and make a photo at Q3. Then, when the image was approx. 90% rendered, SH3D closed without a warning. The second and third attempt failed miserably. Then, oh wonder, on the fourth attempt the programs runs just fine, as if nothing has happened. I can even insert models and make a picture at Q3 and Q4. I even loaded a design made with v3.1 and it rendered without problem. I then ran the installed v3.2, and loaded the same design: SH3D crashed while loading. I repeated the exercise with the installed v3.1, again loaded that same design, and again SH3D crashed while loading. V2.6, installed from the software repository, did load that same design, but crashed when I tried to make a picture using 3D view --> Create photo. However, when I used the plug-in by clicking Tools --> Create advanced photo the model was rendered without a problem. However, when I tried Files --> Preferences the program crashed. Hopefully this gives you some ideas as to where to look for a solution. If you need any further testing, please let me know. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 6, 2026, 10:20:39 AM |
