Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: The SH3D file failed to load on the web using Sweet Home 3D Viewer » » » » Post: Re: The SH3D file failed to load on the web using Sweet Home 3D Viewer |
Print at Sep 6, 2026, 9:35:02 AM |
| Posted by Puybaret at Apr 25, 2011, 12:27:02 PM |
Re: The SH3D file failed to load on the web using Sweet Home 3D Viewer I downloaded the files furnitureCatalog.zip, additionalFurnitureCatalog.zip and texturesCatalog.zip. Did you change these files?Then uncompressed these zip files and placed the png/modle into it from sweethome3d.eu and then again zipped in the same way. Could you give an example of a piece of furniture you defined once modified.Did you also try the furnitureResourcesURLBase and texturesResourcesURLBase parameters available in SweetHome3D applet? See how they are configured in Sweet Home 3D Online for a real world example. By the way, I recall that you mustn't reference 3D model and icon files hosted on sweethome3d.com server, to avoid consuming too much bandwidth. You must host them elsewhere. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 9:35:02 AM |
