Print at Mar 16, 2026, 7:30:43 PM
Posted by alied at Apr 21, 2011, 8:50:16 PM
Re: Plugin - Creating Objects with other Properties
Still, there is something you can do without messing with the code.
in your Plugin constructor, get the Home and add a listener:
getHome().addFurnitureListener(new CollectionListener<HomePieceOfFurniture>(){
void collectionChanged(CollectionEvent<HomePieceOfFurniture> ev){
//check whether it is a ADD action
//get the newly added item (which should de a HomePieceOfFurniture)
//here, either remove your listener (in which case you should not
//use a anonymous listener like here)
//or check whether it is your class or not
//if it is your class, end(remember to add your listener if you
//previously removed it)
//otherwise, create your own object from the newly added HomePieceOfFurniture
//add it to the Home
Next, create a PluginAction which shows your properties dialog (which you might extend from com.eteks.sweethome3d.swing.HomeFurniturePanel if you are interesred in) iff the selected items(s) are of your class.
I hope this can hep you.
